itop菜单栏处理不用改源码,修改扩展类
itop开发内容
1
2083
修改扩展类里边的
model.itop-service-extension.php
添加到
文件代码如下:
class ItopHubMenusShow extends ModuleHandlerAPI
* iTop Hub menus are defined in PHP instead of xml to avoid people overloading them through a delta.
* Do NOT refactor them to the xml.
* @throws \Exception
public static function OnMenuCreation()
$oUserProfile = metaModel::Getobject('URP_UserProfile' UserRights::GetUserId());
if (is_object($oUserProfile)){
if ($oUserProfile->Get("profileid") == 5)
$oHubMenu = ApplicationMenu::$aRootMenus;
unset($oHubMenu[9]);
ApplicationMenu::$aRootMenus = array_values($oHubMenu);
感谢大神:性本善良 我愿平凡
