jenkins 简单实现php集成上线部署
Linux
0 2249
安装/检查JDK
sudo yum install java-1.8.0-openjdk java -version
安装Jenkins
wget -O /etc/yum.repos.d/jenkins.repo http://pkg.jenkins-ci.org/redhat/jenkins.repo rpm --import http://pkg.jenkins-ci.org/redhat/jenkins-ci.org.key sudo yum install jenkins
如果不能更新源,也可以直接下载rpm包进行安装:
wget http://pkg.jenkins-ci.org/redhat-stable/jenkins-2.7.3-1.1.noarch.rpm rpm -ivh jenkins-2.7.3-1.1.noarch.rpm
配置Jenkins的端口
vi /etc/sysconfig/jenkins JENKINS_PORT="8888"
启动Jenkins
service jenkins start
初始密码:
cat /var/lib/jenkins/secrets/initialAdminPassword
第一次访问,通过Web页面登录后,修改Administrator的密码。
rm /var/log/jenkins/jenkins.log service jenkins restart
配置Git账户
git config --global user.name "wsnbackend"
git config --global user.email wsnbackend@gegolab.com
git config --list
root@iZuf6a6ydemt9fvgy22rcqZ ~]# ssh-keygen -t rsa -C "wsnbackend@gegolab.com"
Generating public/private rsa key pair.
Enter file in which to save the key (/root/.ssh/id_rsa): 【回车】
Created directory '/root/.ssh'.
Enter passphrase (empty for no passphrase): 【回车】
Enter same passphrase again: 【回车】
Your identification has been saved in /root/.ssh/id_rsa.
Your public key has been saved in /root/.ssh/id_rsa.pub.
The key fingerprint is:
cat ~/.ssh/id_rsa.pub
[需要将部署账户添加到项目]
[登录wsnbackend,配置公钥]
ssh -T git@gegolab.com
修改Jenkins为root权限运行
gpasswd -a root jenkins # 将jenkins用户添加到root组
vi /etc/default/jenkins
JENKINS_USER=root
JENKINS_GROUP=root
为jenkins用户添加sudo免密码
vi /etc/sudoers jenkins ALL = NOPASSWD:ALL
添加新项目
源码管理
1.选择Git并添加项目路径
git@git.gegolab.com:backend/sms.git
2.添加认证信息
点击Credentials右侧Add按钮,添加一个新的Jenkins Credentials,在打开的对话框中选择kind为SSH Username with private key。
SSH Username with private key:
private key 直接输入:
cat ~/.ssh/id_rsa  # gitlab用户wsnbackend@gegolab.com的私钥
3.处理submodule
点击Additional Behaviours ,勾选Recursively update submodules
Jenkin构建后指定Shell
在构建模块下点击增加构建步骤,选择Excute Shell,输入:
#mkdir /data/www/sms
sudo chown -R jenkins:jenkins /data/www/sms
\cp -rf /var/lib/jenkins/workspace/sms /data/www/
cd /data/www/sms
sudo composer install
sudo chmod -R 777 /data/www/sms
sudo chown -R www:www /data/www/sms
以上Shell将会在代码拉取成功后执行。
